70 Plymouth Duster 45,000 miles
3:13 AM
MN
Lost my job. Single father of two. I regret selling this but the kids come first.
1970 Plymouth Duster. $19,000.00
PlumCrazy Purple, This car is very low miles & has never seen winter roads. Absolutely no rust on the body nor chassis. The car was proffesionaly completely restored. Body off restoration. New Paint 2 years old, Complete new drive train bumper to bumper. Only 1,000 miles on complete restoration. Dyno specs available.
New Interior
Custom Seat upholstery. Custom cut padding. No skins.
New carpet, small cuts next to shifter housing.
New Head liner,
New Door panels, Front & Rear
New sill plates,
New rear window panel,
New seat belts,
Dash pad is perfect ( OEM )
New Glove box ,
New cat whiskers,
New Lamps
Ralley 150 mph Dash panel, no cracks, perfect but needs to be rechromed
New Complete Interior & exerior rubber/seal replacement
No cracks nor chips in windows
Exterior Everything is New
New Paint Not one Scratch
New Stripes
New remote drivers mirror
Front & Rear bumpers rechromed, Chrome bumper bolts, not chrome caps
New front & rear window seals, New Trunk, door seals & body plugs
New side marker lenses
New Sharktooth grill, no cracks,chips or repairs.
New lower rocker panel Chrome.
New wheel well Chrome molding.
Lift off Custom Fiberglass hood
Chassis Every thing is New
Front suspension completely rebuilt with Just Suspension components.
Upper & lower control arms rebuilt.
New 90/10 Calvert front shocks
New rear Rancho XL 9000 9 way adjustable shocks.
New Mopar Super Stock Rear springs. with 1" offset hangers.
New Quantum gas tank & straps. 1/2 " Fuel pickup.
Heavy duty torsion bars & Frame connectors.
Brakes: Every thing is New.
New master cylinder
New Front to rear brake lines from In - line tubes
New upgraded SSBS front slotted rotors, 4 piston calipars.
New Rear B body Drums & Components.
Completely new drive train. Bumper to bumper is brand new !
Engine: over $17,000.00 invested
OEM 22" 3 core radiator & OEM Shroud.
New Custom Built R3 360 416 C.I. 520 Hp
R3 360 Block Stroked MP P4876796AB
4" Cast Crank MP P5007258
Eagle H beam Connecting rods
Ross 16 - 32 Pistons
Total Seal Rings
Milodon 30940 Oil Pan
Internnal Pro-Race Damper
Edelbrock Performer Heads 60779 Ported & polished
Indy rocker arms
Cam Motion Solid Camshaft 52564-10+4 Valve Lash .023 Dur @ .050 i = 256.5 E=256.4 Valve lift .54698 Have spec sheet.
Edelbrock 7576 RPM Intake
TTI - 340A - C5 Headers Polished Ceramic Coated. 3" ehaust with X pipe & flow thru mufflers.
950 Holley Street/race Carb
Mallory Ignition 6AL Mallory Pro Billet Distributor, MSD Blaster Coil
Power Master Master Torque XS Starter Have Dyno sheet.
Schumacher Motor mounts
1/2" braided fuel line
Aeromotive electric Fuel pump, Aeromotive 10 micron fuel filter
AutoMeter Gauges Tach, temp, voltage, oil psi with low oil pressure engine shut off.
Radiator over flow bottle
Hurst Line lock
Tranny: Built for Street & Strip
904 Competition Tranny, 2.74 wide gear ratio gear set, Deep Pan & pickup, 999-5 Clutch drum & with 1.75 offset band. Low pressure drop with stacked plate cooler with by pass. Teflon sealing rings
10" 904 A o/s Ultimate Torque convertor with flexplate, 3200 stall. H.D. 1330 slip yoke
T.A. Valve body Manual Reverse Shift Pattern. Trans cooler mounted in front of radiator.
Cheetah SCS Turbo Action Shifter with Line lock control.
New Engine froward Light Wire Harness, New dash to rear wire harness.
Wiper motor is not installed. Car isnt driven in the rain.
Rear end:
8 3/4 489 Case. 3.91 Richmond Gear set Solid spool, Moser 30 spline axels with 4.5 B.C. Bearing
H.D. Custom balanced Drive Shaft
Tires & Wheels: All New
Fronts Kuhmo 15" with Crager wheels Rears: Goodyear Eagle SS DOT 325 / 50 / 15 with 10 x 15 5.5 bs Cragars
I have all the receipts for every thing listed. I'm regretfully selling my car because of employment issues. My loss is your gain.
I have over $48,000 invested in this car. Everything is new.... This car has been built with top of the line products. All performance parts used in the drive train. This car is fast, Low 11.00 1/4 mile & looks awesome. Pictures do no justice. Save your self $$$$$$$$ by buying a car thats complete
Thanks Everyone. More pictures if needed.
1
Beautiful car! Love A-bodies!
Is that a black and white picture in front of the car from Northstar Dragways? If so, thats way cool!
You have a keen eye..........Yes it is. Thats from 1979. Me having a blast. I display that picture at car shows. The guys our age love it. You can't believe the conversations that sparked by that photo. Lots of fun..
This is a great looking car. I hope thing turn around for you before you have it sold.
