zigs
I have a question. I bought a Taurus 2sd fan and a Delta controller. I haven't gotten the controller yet but going through instructions on line , it seems I can use my existing ignition wire from fuse block to fan . It also says that a power wire is run from the fan to battery and an inline fuse should be used but they don't say what amp fuse . The controller is designed to come on slow to eliminate power spikes. Should I use at least a 40 amp? This is the Delta
2sp controller and yes I have a 100 amp alternator .
