Logan Hughes
While I was having the machining work done on my 440 for my rebuild, I took the time to work on my Dana 60. I removed the cover plate, drained the fluid and replaced the cover gasket. Since I had a small leak at the pinion seal, I also replaced that and filled with Lucas 80W/90W lube. The weird thing is that my new pinion seal is leaking! Has anyone else had this issue and how did you fix it? Any advice would be appreciated. Thanks!
