Gpuller
We are working on a '70 Charger and it will have EFI. Plan is to have a Tanks EFI fuel tank with in tank pump.
Trying to figure out a clean method of plumbing the system. Would it be possible to use 5/16 factory fuel line for return and a 3/8 factory line for supply? Could they occupy the same space or made to work side by side? Then possibly use compression fittings and fuel hose to connect to tank and EFI up on the engine.
