66Hemi
Acquired the correct Prestolite DP dist for my stock 440-4V. Currently, runs OK on pump premium with stock SP dist.
With DP dist installed, been told I will need to run CAM2 (or equiv) higher octane fuel. Get the need for performance runs, racing, etc.
Q1: Will higher octane fuel be req'd for normal cruising?
Q2: If so, will a fuel mix w/ pump premium meet reqs?
Q3: If so, fuel mix rec?
Thanks!
Thanks!
