You might consider buying 316 SS 1/4" round tube stock, then cut to fit and tap the threads. Every scoop and hood combination is potentially slightly different so off-the-shelf might not be available.
I mocked up the exact length by cutting a pencil and propping the 2 pieces in place. Stand back and look at it from different angles, comparing to photos such as the one above.
Once you have the location, then drill holes. A final trip to the hardware store to get the washers and screws and you are all set.
