RobsRR
I just rebuilt an upper control arm. I replaced a ball joint and had standard Moog rubber bushings pressed in. In the process of installing them I noticed if I tighten the cam bolt to the recommended 65 foot pounds the control arm will barely move. If I loosen the cam bolt a little the end caps turn as the arm moves. If the end caps move it is metal on metal? Something doesn't seem right. I did not put the ball joint into the spindle yet. I also saw somewhere that I should not tighten the cam bolt until the suspension is loaded. Any thoughts?
