Ignition timing
steve from staten island
4:37 PM
staten island,ny
Can someone explain the proper way to time my 383 2 barrel engine. I do not understand how to set the total timing at a higher RPM in relation to setting it at idle. Were should my timing be set? The specs i read for this engine when i used that the engine ran poorly. Thanks
Total timing (or advance) is directly related to initial timing. As you advance initial more, the total goes up the same amount. The mechanical plate in your distributor should have a number on it, such as "12" for example. That means your mechanical has 24 degrees (12x2=24).
On a small block, you want to be around 34 to 36 total timing. So if you have 12° initial with a "12" mechanical plate, your total is 36°, if you know what mechanical advance plate you have.
Or, once you have initial set, use an advance timing light and rev the engine up until it doesn't advance anymore...there is your total. Stock advance springs will be all in timing wise higher up the rpm band than some lighter aftermarket springs.
If you are above 12° initial, you need to limit the mechanical advance somehow. Otherwise you may run into detonation.
Always adjust your timing with the vacuum advance disconnected and the hose plugged, to prevent the vac advance from possibly affecting your readings. Reconnect it when you're done.
Mopar%20Timing.pdf
Components That Affect Timing
Distributor – the primary device, which is adjusted to establish minimum timing.
Vacuum Advance – a device that increases or decreases the timing by moving the distributor plate. It is controlled by the amount of vacuum the engine produces. The source of the vacuum is a ported opening in the carburetor. Mechanical Advance- consists of weights attached to the distributor shaft, controlled by coil springs attached to the distributor plate. Centrifugal force created by the speed of the turning distributor shaft is transferred to the weights attached to it.
Total timing is determined by measuring Initial timing (distributor setting) + Vacuum Advance (the setting of the small diaphragm can attached to the distributor) + Mechanical Timing, the advance caused by the weights attached to the distributor plate and controlled by the strength of the springs.
Correct adjustment of timing affects the quickness of the engine starting, gas mileage, amount of horsepower, rod bearing life, valve ping, and idle quality. Timing that is set outside the parameters of the capability of the engine may cause severe damage to the engine.
PROCEDURE
Step One Determine the base line of the settings that affect timing and write them down.
Initial timing
-Start with a COLD non-running engine. Find the timing mark on the vibration damper (the big round wheel about 1 inch thick behind the belt pulleys at the very bottom front of the engine). It is a perpendicular mark that is cut into the damper. Clean the mark with an appropriate shop cleaner such as WD40 so it is clearly visible. If it is not clearly visible after cleaning it use an artists brush with white paint to paint a thin line on the mark.
-Attach Mopar timing tape or measure and mark degree increments on the vibration damper to about 40 BTDC. (Note 1 inch equals 16 and 2 1⁄4 inches equals 36.
-Find the degree gauge usually attached to the timing cover and visible from the top of the engine. Clean it also, so the numbers and marks are clearly visible.
-Find the distributor hold-down clamp and bolt. Loosen bolt then tighten very slightly.
page2image19672
page2image19832
page2image19992
page2image20152
page2image20312
page2image20472
2
-Find and disconnect the vacuum line to the distributor. Connect the vacuum gauge to the line.
-START ENGINE, outside of garage, and run until Engine operating temperature is reached and choke is completely off, transmission in Park.
-Determine your vehicle’s ideal idle speed in RPM; usually 600-800 RPM. If you have a high performance cam it may be as much as 1100 RPM.
-Connect tachometer to determine idle rpm (SEE DRAWING No. 1). -Adjust carburetor idle screw to achieve desired rpm.
-TURN ENGINE OFF.
-Connect Timing Light (SEE DRAWING No. 2)
-START ENGINE and point timing light at mark on damper.
Record the timing reading and the vacuum reading.
-Disconnect the vacuum gauge.
-Re-connect the vacuum line to the distributor.
-Run the engine up to 3000 RPM, point timing light as above. - Record the timing reading.
-TURN ENGINE OFF
You have now established the theoretical minimum and maximum timing. Mopar performance recommends a maximum (total) of 35 BTDC for street engines. The following step will identify and quantify the source of timing which exceeds the minimum (initial) timing.
Step Two
-Disconnect the vacuum line to the distributor.
-Connect a vacuum gauge to the end of the vacuum tube you disconnected.
-START ENGINE, RUN UP TO 3000 RPM, repeat with timing light as above. Record the timing reading and the Vacuum gauge reading.
-Subtract the first maximum timing reading from the second maximum timing reading. The difference is the number of degrees of advance timing the vacuum system is adding.
-Subtract the minimum (initial) timing (step 1) from the maximum timing as recorded in step two. The difference is the number of degrees of advance timing the Mechanical advance system is adding.
Now lets look at an example, which will help you decide the next steps. Lets say the minimum timing is set at 8 BTDC, the vacuum advance provides an additional 13, and the mechanical advance provides 21 at 3000 RPM. 8+13+21=42. This is too much advance timing. We have 3 choices:
page3image19688
page3image19848
page3image20008
page3image20168
page3image20328
page3image20488
page3image20648
page3image20808
page3image20968
page3image21128
3
  1. 1) Reduce the minimum timing (initial) to a point that 35 is achieved by the above tests. Set up the minimum timing procedure and retard the distributor to a number less than 8, then re-measure everything again. Keep adjusting and measuring until the number is achieved. OR;
  2. 2) Reduce the Vacuum advance to a point that 35 is achieved. This done by removing the vacuum line at the canister on the distributor and inserting the 3/32 inch Hex head Allen wrench, through the hole where the line was connected, into the set screw (inside the canister) and turn the screw to the right (in) to reduce the amount of advance (or left to increase). Turn the screw one (1) turn and record the amount “1 turn right”. Re-connect the vacuum line, run the engine back to 3000 RPM and check the timing again. If still too high turn to the right and record the number of turns (or partial turns). Check timing again. Continue to adjust until the 35 is achieved.
    -Alternately you may use the hand held vacuum pump and the reading for vacuum from the first and second step instead of running the engine up to 3000 RPM. OR;
  3. 3) Change the springs on the distributor plate and check timing in the same manner at 3000 RPM. This is a fairly complex process and beyond the scope of this document.
You may have to use some combination of all three to achieve the desirable results which include; easy start, good idle, power throughout the RPM range, and no valve pinging.
Disconnect all equipment and replace hoses. Happy motoring!!!!
The EPA prefers low BTDC settings to reduce emissions. Unfortunately, this is counter to a high performance engine.
If you don’t have the above equipment and/or do not want to go through the involved process, there is a fairly simple procedure to use, which will produce, desirable but not optimum performance.
Steps
-Loosen the distributor hold-down clamp bolt.
-Start the engine and turn the distributor a small amount in the direction that the engine speeds up. This is advancing the timing. -Tighten the bolt without moving the distributor.
-Turn engine off, and then re-start. It should turn over without hesitation and start quickly. If not reduce timing slightly.
-Test drive the vehicle. From cruising speed (about 50 MPH) accelerate slightly and listen for valve noise from under the hood. Accelerate fully and observe valve noise and vehicle performance.
page4image22176
page4image22336
4
If no valve noise, repeat the entire process. When valve pinging is heard reduce the advance by turning the distributor slightly in the opposite direction from above. Re-test and adjust if needed. Once this state is achieved your engine is handling all the advance timing it can take.
‎tvmoparclub.com/files/tech/Mopar%20Timing.pdf
OK Steve, the first thing you'll need is a timing light and be schooled in how to use it. Next, go to this site for detailed instructions:
https://itstillruns.com/time-mopar-400ci-4bbl-8255404.html
These instructions are for a 440 but they are identical for 383's and 400. Work safely, keeping clothes and hands away from moving parts as well as the timing light leads. I like about 12 degrees below top dead center. To know your total timing, replace the vacuum line to the distributor and rev the engine to about 2500 rpm while observing the timing marks advance. The problem here may be that your indicator plate may not go to a high enough value in which case you'll have to mount a timing tape on your harmonic balancer. Good luck.
Why not use a dial back timing light, set it to 35*, run the RPM up to 3000 and lock the distributor in at 0* on the timing mark? That's what I did and the initial fell in at 12* or 14* (I forget exactly).
