Malicious
Hi all just put in a return style fuel regulator, I was jut looking to get a few things done to get some better efficiencies and drivability, and I hit a few concerns.
I'm running this style of regulator: with a direct gauge mounted in the regulator
https://www.summitracing.com/int/parts/edl-174133
First up, adjusting the upper bolt did nothing to the fuel pressure. On start up and cold cycle it stayed around 8.5-9psi then after it heated up it was around 6.5psi.
I'm running a mechanical fuel pump, hemi style unit.
the regulator is meant to be 5-10psi, so it should adjust, is it buggered, or am I doing something wrong?
OR a thought, is the mechanical pump just not powerful enough to warrant the regulator?
