You can make alot of power with low compression engines, it just does it at high RPM, and the low end torque is somewhat ignored by using high stall torque converter and more gearing. This is fine if you have a drag race car or weekend hot rod, but is not a good option for a true street car.
The cam I mentioned was just a guess, we really need to know the vehicles application, true compression ratio, converter stall speed, gear ratio, tire size, and intake/exhaust system. Also fuel being used and altitude driven at.
The camshaft you select will affect the "shape" of the torque curve, and you want the torque curve to match the rest of the car combination and the application or how the car is being used.
For a "street" car you may have better results with a smaller cam that makes 450 ft/lb of torque, but only 350 HP, than a cam that makes 450 HP, but only 350 ft/lb of torque?
