65 dash
300
2:05 PM
Canada
Are the 65 Belvedere dash pads the same as 65 Satalite. Thanks in advance
65
Thanks for reply,, so was the Satalite Model a Belvedere Car Dumb Question i know, what were the difference between the 2, parts interchange?
Just got this so trying to figure out
65 Satallite
Thanks guys. Keep the info coming, what are the hard to find stuff, What else iis the same as Belvederes
A lot of items found on the '65 Satellite or '65 Belvedere are hard to find. only a one year body. however '64 fury is a cousin car and has some body parts that will work, or parts of body parts. they are repopping the floor $$$. but, it is the detail things that are hard to come by. I am looking for the side trim for my '65 Belvedere and still haven't had much luck. If you want bucket seats that is a Satellite thing, the 64 Sport Fury stuff will work. infact, other that the tracks the "A" body seat will work. Center consoles '65 Satellite, the '64 SF is almost the same (dome lights are different). I also think some '66 models have the console but i think the top is different.
The parts between the two are all interchangeable, it is a trim/option difference, they are the same body. Again the bucket/console thing is a Satellite,(holes would need to be drilled into a Belvedere floor for this option and console brackets put in).
What exactly are you doing?
Center consoles are the same for 64-65 regardless of make (dodge-plymouth). 66 is a whole other animal. Bucket seats are the same 62-65 (dodge-plymouth).
OOOps I meant the '65 "C" body console (some are the same except the top, and some have extensions on the back end) and there is a difference between the '64 and '65 "B" body console. The difference is the lights on the side. the '64 has smaller lights and the '65 has the larger bezel. they will interchange either way.
Not making it a # matching project. Won,t be using console I have, will be changing from auto to 4 speed and 318 to something much bigger. Thanks
