Let's see em. From all different angles, firewall, brake booster, power steering, etc. Just trying to get as much info as I can for my build.
no.Thank you! Does it have a vapor separator/fuel filter between the pump and fuel T?
I have the same thing on mine, it has a dual master cylinder and front disc brakes, which I plan on keeping. I have to put the power brakes back on it, so I guess using a 67 gtx brake line kit would be the answer to that?Brake master cylinder is 67 , but otherwise I think its correct
If you need anything let me know. Its in the garage
View attachment 1134252 View attachment 1134253 View attachment 1134254 View attachment 1134255
Thank you, good to know. Yes, it has the hemi single master cylinder on the power unit.If you have a single line master cylinder DON'T trash it. They've a larger reservoir. it's taller they're unobtainable. You can see one in this picture.View attachment 1134268
Is your ps pump correct as mentioned above by gtx9670?Mine are 67's. Basically the same other than dual master cylinders. View attachment 1134260View attachment 1134261View attachment 1134265
None are 100% correct for the nitpicks, just a good representation of 67 Hemi cars.
Could you snap a pic of the steering wheel and horn ring please? Thanks!Brake master cylinder is 67 , but otherwise I think its correct
Interesting... Is that hemi only??? Never seen a tall oneIf you have a single line master cylinder DON'T trash it. They've a larger reservoir. it's taller they're unobtainable. You can see one in this picture.View attachment 1134268
I don't about you for a long time parts were expensive! I had a 69 Coronet with discs in 1973/74 needed a caliper $175 that was real money then. Glad my car didn't come with them.Then mine wouldn't be the good one. It had 3" drums
Thank you, so yours is a satellite or a belvedere? I'm trying to find out what a stock belvedere II steering wheel looks like so I can get one. It currently has a really nice wood wheel with chrome center and the horn even works, but I want original. I know they are 2 spoke, and there are 2 different horn rings like yours and one with a red dot in the center.
