Dragon Slayer
I am having a confusing problem with the front Driver Flasher. First of all, the turns signals work correctly all four corners including dash and hood turn signal lights.
Move to flashers and only the Front Right and both Back will flash. Not the driver front, or the dash or hood left turn signal light/indicators.
How is that possible if the turn signal will work, and when using flashers the driver rear will work?
Looking at service manual the flasher signal that goes to front left looks like it also goes to the steering column connector for the turn signal switch. Seems that is how the rear get flashing signal. So if the rear flash, why not the front? Unless I have a cross wire in the steering keeping the rear on?
The only other anomaly is if the headlights turned on, the dash left turn signal indicator comes on. Any help appreciated.
