Vertburt
Hi. Trying to get me 70 satellite running. Been sitting for 35 plus years. The only power I had was the the headlights and after new ignition switch I can crank the car. I took the cluster out today and if I hooked the battery up nothing would happen. So I put the cluster back in and hooked the red and black wires , I thank amp gauge wires and it started smoking at the bulkhead, Blue wire and I think a black wire. Then hooked everything else up and screwed it back in and still with switch off, if I hook battery back up, the blue wire starts to smoke again. Any help would be appreciated. Thanks
