- 6:10 AM
- Jul 1, 2015
The alternator is not intended or designed to charge the battery. It only maintains the charge and powers the rest of the cars electrical demand. The battery is to start the car and excite the diodes in the alternator to induce a magnetic field. Dead battery, dead alternator. Slow charge the battery to full charge. It could take several hours. Test to at least 12.6 volts at rest. Load test pulling a 50% load. Should maintain 9.5-6 volts under load. If it doesn't, needs new battery. You can't check an electrical system without having a fully charged battery first. Otherwise all other test are not going to be accurate.
Totally incorrect.....the alternator's function is to charge the battery AND to supply ancillary power for electrical accessories.
The battery does not "excite" the diodes. The magnetic field is produced by the ROTOR, inducing an AC current (and voltage) in the STATOR WINDINGS, which are rectified, or changed, to DC voltage and current by the diodes, configured in a three phase full wave bridge rectifier circuit. The rectified power is presented at the output terminal and ultimately to the battery and the car's electrical system.
Regarding proper test procedures, your best bet is to follow the FSM for your particular vehicle. Using a variable load device, measure the battery's terminal voltage, following FSM values, typically not less than 10.5 volts at the perscribed load (450 amps) for a perscribed amount of time (15 seconds). REMEMBER...a lead acid storage battery does not store electrical energy but stores chemicial energy. The battery's ability to absorb and release energy, on a cyclical basis over time deterriorates. The longer the battery's ideal state of charge (14.0-14.5 volts) can be maintained, by a functioning alternator, the longer the battery will last. Another test of a battery's state of charge is to measure the specific gravity of the electrolyte, when possible. An ideal specific gravity would be 1.260-1.270. As the battery's charge level goes down, the specific gravity will drop.
Just something else to consider.
BOB RENTON
