- 11:38 PM
- Oct 8, 2012
- Valencia, España
I have had similar random no starting situations. In my case was the distribuitor pigtail wire/plug. Had couple of times shaked this and started up. Replaced the full dist pickup assemby and got it fixed. Pickup coil was really good but not the pigtail. So I saved it as spare to replace the wiring pigtail later.
You can unplug ECU and test the pickup coil wires at ECU plug. The regular reading should be 250-290 ohms but anything between 150-900 is good. This will test the dist plug at the same time.
