- 3:27 PM
- May 14, 2011
- On the Ridge, TN
Greetings y'all.
In the next step of the long-term resurrection of my '68 GTX, I'm on to the next problem now that the basics are all in place and functioning - finally. Thank God.
Car has replacement 440, new clutch (Centerforce) etc. and a replacement "donor" 23-spline.
Driveshaft is stock. Rear end is a fresh rebuilt 8 3/4 with 3.55 and SureGrip.
Anyways, at speeds over 70mph and under load, a fairly heavy vibration occurs and just gets worse with more speed. If I lift, it goes away. If I push in the clutch and/or pull it out of gear at that speed, the vibration goes away. It isn't in the engine or clutch or in wheels.
This is telling me there's a possible problem with the u-joints - or even in the tailshaft housing, so I got under the car and checked things out.
Rear u-joint checked out fine, but I took it loose and reinstalled it 180 just in case I had installed it "clocked wrong" before.
Grabbed the driveshaft yoke at the rear of the tranny and Bingo - there's quite a noticeable amount of slop here. I had replaced the seal on the transmission when I got it, but the actual condition of the transmission was a total unknown before.
It shifts really nice and it's a quiet unit, but this slop at the output is almost definitely the cause of the vibration.
Is there just a bushing that needs replaced in there? Is this something I can do?
Or is there more to it?
