Advice on restoration of my interior window trim
Doubleclutch
5:05 AM
Jupiter Florida
My Road Runner came with degraded window trim from the sun. The grained finish is really flaking. Just a slight brush makes a mess. Our local restorer says he restores these by sanding to metal or to healthy coating, then applying a heavy coat of primer and while the primer is still soft, blotting with 80 grit paper and applying a slight shift of the paper, then sand and color finish. We will see.
Any other solutions?
Chuck
if you are talking about the vinyl pieces, you can take these and do a gentle bead blast on these that will take off the loose parts. to get the grain look back, take a spray can of bedliner and paint your pieces. then you can re-dye with any color you want. the black bedliner will cover with a couple of top coats . what ever suits you. i used this on my challenger interior trim about 10 years ago and it stilln looks good
Would really like to see some photos showing your results.
