I am starting into the engine build for my '63 Max Wedge project. I am wondering about the head choice ? I am using the original style cast iron exhaust manifolds, so they are heavy, and with the angle they sit at, will tend to pull away from the head. My question is are aluminum heads strong enough to hold these manifolds over time, or would I be better off using a cast iron manifold. I should also add, at the current time, I have neither, so I need to start fresh on the build and would like any input from what others may have found out...Thanks
