I was to attach an example of a non fancy jumper which will be enough LOL
Yes I have had REAL CHALLENGES... once a missfire which I found it was a reversed dist pick up wires made by somebody in the past. This was before I learnt about.
The greatest challenge was a discharge reading but 18 volts at batt iddling. when giving RPMs, voltage raised up to 24 but the ammeter barelly read slightly passing by the center. On both stages the engine stalled when disconected the batt.
Failure ? one of the vent vanes of the rotor was geting friction with one of the leads of the diodes bank, causing a pulsating short while spinning. It took me around an hour and a half to get it. It was at the next day I replaced the rotor in it, but tested on bench was everything good
Parts in Vzla ? Chrysler had assembly plant back from the 50s up to lates 70s ( my car was assembled in Venezuela ), so there was many Mopar parts dealer, and still now some with NOS parts ( I have got NOS valances, driver door, Tail lights and some smaller stuff more for my car ). Sure latelly is being harder and they are closing their doors.
Mine is 74, but in Venezuela 74s were wired like a 71 somehow ( without any of the seatbelt sensors stuff ). I become it into a Northamerican 74. It was a "partial" rallye look, but standard cluster so I also got a Rallye cluster from USA fairly cheap ( when it was still posible yet ) with switches and knobs ( wiper knob is hard and not cheap ), Found a NOS rear sway bar locally, got the rest of parts used from USA so added the rear sway bar to become it on a full rallye. Then found locally some Kmh speedos, hard to find on Rallye clusters because they were equipped on some really hard to find 74 Special Edition Coronets and become my Rallye cluster on a Kmh speedo. Had to mix several speedo parts because were damaged. Of course my standard cluster was km.
I'm right now in Spain ( so you can find a reason for some delay on some responses... timezone ), waiting my car is finished from a deep body and paint job in Vzla and bring it to me. If dictatorship in Vzla doesn't block anything else. I still have to go back to Vzla to assembly it. Engine is being fixed too.
