Any Canadian Help??
djais1801
7:57 AM
east side
My car was made in Canada, I found an old classified ad from 2 owners ago that stated it was a SSP w/ a 318 originally..how can i verify what it came out of the factory with?
Does Canadian DMV have records if I get them the vin?
post up the numbers off the fender tag/buildsheet if it has one
and someone will decode it for you here.
the vin number will tell you a few things also
unfortunately it came with neither the fender tag/build sheet.
i know it came outta Canada (the brake drums still say made in Canada)..it has fixed rear quarter glass/no roll down.
vin: RH23C1R203131
Model: Plymouth Belvedere or Satellite R
Price Class: High H
Body Type: 2 door hardtop 23
Engine: 225ci slant 6 1bbl (RG motor) C
Year: 1971 1
Assembly Plant: Windsor, ON (Canada) R
Sequence Number: 203131 203131
thats about all you are going to get
without a fendertag/buildsheet
i appreciate it Flypaper!! So I am sure it was just a base model Satty, did they make SSP's with a 6 banger?
that, i do not know for sure
but i'm sure someone will chime in to confirm.
i do know the 318 71 base satellite i parted
had the vin of
rh23g1g226903
so it could be just a base satty
but that just a guess on my end..
If the price code is high. It is a Satellite Sebring, not a base satellite. At least that is my understanding.
R- Belvedere or Satellite
H- Satellite Sebring
23- 2 Dr coupe
C- Special order slant 6
1- 1971
R- Windsor
203131- sequence number.
thats sort of odd.
the car i parted was 99% complete and in orig paint
and it did not have a sebring emblem/marking on it anywhere?
it did have a/c and 11 hd brakes and a
couple other options on the fender tag
gotcha
i know in 70 a RL
was called a belvedere
