Couple degrees difference in the angle of the steering box. Will work though. Main difference is the sway bar setup. 67-69B goes under the k-frame. 70B and E the bar goes through the K-frame and the K-frames are different as well as the sway bar tabs on the LCA's.
Will an E frame work in your 69B? Yes. Is it correct? No.
Top one is a 66-69B and the lower is a 70-2B 70-4E.
