From NHRA rule book: Batteries may not be located in the driver or pass. compartment. Rear firewall of .024-inch steel or .032-inch aluminum (including package tray) required when battery is relocated to the trunk. In lieu of rear firewall, battery may be located in a sealed .024 inch steel, .032 inch aluminum or NHRA ACCEPTED POLY BOX. If sealed box is used in lieu of rear firewall, box may not be used to secure battery and must be vented to outside of body. Relocated batteries must be fastened to frame or frame structure with minimum of (2) 3/8 INCH diameter bolt hold down method described in previous sentence. (J-hooks prohibited or must have open end welded shut.) Metal battery holdown straps mandatory. Strapping tape prohibited. A maximum of (2) automobile batteries or 150 lbs. combined maximum weight is permitted.Maximums may vary according to class requirements Hope this helps. Go get 'em!
