3:54 big block, 3:73 small block.
That's a good cam with at least 10 to 1 compression motor. I built mine to six pack specs. I was running the purple shaft solid 296 557 and the car was actually faster. 12.30sI was recommended a cam with a .509 lift with 292 duration could I get similar times with a cam like that
Yes I'm thinking about 4.10s but I haven't sprayed my combo yet and don't want to put in a roll bar. I had 4.10s in my 70These guys are all nuttier than squirrel turds. 4.10's is all ya need.
So if I run the same gears and stall as you and my engine wouldn't be built the same as yours but if I run the .509 cam you think I could at least get high 12s low 13sThat's a good cam with at least 10 to 1 compression motor. I built mine to six pack specs. I was running the purple shaft solid 296 557 and the car was actually faster. 12.30s
GTX and think it is actually the perfect gear. Before I raced on the streets but I won't do that anymore so 4.10s is right at the limit to drive to the track.
It's hard to say but if you check out the 12 second section in the racers section you will find a few cars with that cam and some give their combo's. That may help you with yours.So if I run the same gears and stall as you and my engine wouldn't be built the same as yours but if I run the .509 cam you think I could at least get high 12s low 13s
