JR_Charger
Not run since early 2000's.
The condition of the camshaft -
The condition of the valvetrain -
This is as far as I've been in a motor before. It looks like the heads are held on with these bolts along the bottom of the head, and around the valvetrain -
I'll have to look into how to disassemble it from here. I thought the heads would unbolt and lift off, but I believe I've seen the pushrods installed after the head, so they must come out first.
If the pistons and cylinder walls look o.k., my game plan is going to be to mildly upgrade this engine and find another one to build for power later. I feel like I've got enough to sort on the car without the possibility of screwed up engine internals. Porting and polishing the heads seems reasonable. Uncle Tony bought a big grinder off Harbor Freight, but I've seen another guy do it with a Dremel. I picked up a bunch of grinding stones for another job a couple weeks ago, and ended up not needing them on that job, maybe I can use them here. If it turns out the Dremel isn't powerful enough, I'll get the big grinder. I have a feeling this won't be the last port and polish I do.
The only problem with my mild upgrade plan is, this is a great time to do the camshaft; and AFAIK supply chain issues haven't gotten any better. I don't have the experience to spot a bad cam or lifter. I don't know about camshaft bearings either. Looks like that would be hard to do with the block in the car, but after 5 years of restoration, I'd like it to have a little more grunt than it did when I last drove it.
