Beavis
i just rebuilt a 68 carter avs carb for my 383 dart.
i installed everything in the rebuild kit.
i set all the floats to spec. and adjusted all the linkage.
after i get it running and it runs really good with the exception of when i first give some throttle it lags a bit, could this be a timing issue ?
the problem is when i shut it off, then it wont restart without pumping the crap out of the carb like 50 times.
i noticed when i pump the carb with the engine off, it squirts really good the first pump, but then no gas.
i put a new accelerator pump in the carb.
could i have the floats set wrong ??
