Have had these N10Y4 plugs awhile does anyone know what the 4 means?
Anyone have an easy way to remove the crush gasket on them.
Thanks.
Thanks.
In Champion Spark speak, the -4 = A wide gap. The Y = Projected nose electrode. The N = the reach or in this case its 3/4" and the numeral 10 is the heat range running from 6 (cold) thru and including 14 (hot). The standard plug for the Hemi was N-10Y and the origional LA small block was N-14-Y, the origional 340 small block was N-9Y. The origional Max Wedge Stage III was J-9Y with the 13.5:1 compression ratio.Have had these N10Y4 plugs awhile does anyone know what the 4 means?
Thanks.
OB,C'mon Fran, listen to Bob. " J's " are the big block plugs! You're getting "something" in your old age,lol. Now, I'm trying to remember the letter for cut-back side electrode on the J's; d___ it. Jeff
