Lionized
- 6:26 AM
- Mar 23, 2014
- Vancouver Canada
I'm going through a tank of CRC 1 tank right now. Low compression in two cylinders.If it was rebuild and barely run, I would think more likely of corrosion or carbon build up that causes a valve to slightly leak.
The head gasket will be something if the rebuild was not done right and the deck and head were not resurfaced causing a leak.
To me if you rebuild an engine you will never skip that process.
I would put some more miles on it, high way driving with some power on it to burn it clean and after test again.
Maybe throw a known brand of fuel additive for cleaning the internals in the tank. (not sure if that is any good to these engines but on modern engines it does make a difference with a "lazy" engine full of carbon build up.)
Before I used the additive I ran about a quarter cup of water through the primaries after letting it warm up. Slowly drizzle it down each bore a bit at a time keeping the rpm up. Should take care of any carbon build up.
