Was looking for a 727 with a gear vendor. Came across Cope Racing Transmisions. The quote he gave me was reasonable. Wondering if anyone had any experiance with his trannys?
The tranny was there when it needed to be.
Thanks 440beep, how do you like the gearvendor, did you have to do any trans tunnel mods to make it fit? What gear you running & what RPM @ 60 in OD you turning? Thanks for the info.
That sounds perfect! I have 3.73's so should be a couple hundred less RPM I think. I was hoping to cruise 70 @ 2600 so should be close! BTW where about is his shop. With gass prices where they are it may be cheaper for me to drive there from Central Iowa. I'm only 5 hours from Chicago.
BTW spring is getting closer every day!
I may look you up when I come over to see the Bee!
Pulled the trigger! Called John and he was very helpful. Told him what I wanted and expected performance. He recomended the std GV OD as it takes less trans tunnel mods. He said that since I hadn't welded the spring perches yet it should be a snap ( to get the pinion angle set). Also recomended the Bouchlin kick down cable that will work with any carb manifold combo. Very nice man to deal with. He said I'm #6 in line, and I should see it in about 5-6 weeks. which is fine cause I'm a long way from being on the road.
