Inspector71
I wish you all could meet in one place and hold classes. I'd sign up and bring coffee. I've learned more on these threads than from 30 years of reading magazines on the topic.
Generally, it is not in reference to the compression ratio changing,
B.S. We all keep repeating this old mechanics tale. This not true!Another thing you have to keep in mind - all things being equal when you switch to aluminum heads you need to go up 1 point in CR to make the same power.
So true. We've made 525 HP with an 8:1 compression 383. Pulled the engine out of a scrap pile and cut some valve reliefs in the tops of the stock pistons with a die grinder while they were still in the short block (uh, we don't do that any more, but it was interesting that one time). Heads, cam, intake, carburetor and rpm = 525HP.I think with smart parts choices the 383 could see 425 or so HP. More if you're willing to raise compression and run race gas. They can make basically the same power as a 440, but they do it at higher RPM.
