Dents on Windage Tray - Rod Clearance? Stock Stroke
PurpleBeeper
8:38 AM
Chicago
I have dents (aka "witness marks") on my stock (Felpro?) windage tray right in the area of cylinders #3 & #4. It looks like maybe the rod bolts are touching the windage tray on those two cylinders. I've never seen this before. It's a stock stroke motor. What do I do?
The only thing I can think of that caused it is that I've used this windage tray several times. I do have to bend it slightly to slide it around the oil pickup tube to install it (engine in car). Is the rod/windage tray clearance normally really close? Maybe I bent it just enough that those two rods now hit it?
The other "1/2-idea" I had was possibly using a thicker oil pan gasket for more clearance. I've been using cork Felpro parts store gaskets which look pretty thin.
What do you guys think? THANK YOU
Think your 1st guess is correct.
