mountain33
My 71 RR with 383 4bl has an annoying miss. Car starts right up Idles fine but you can detect a miss. I pulled all of the plugs today they look great, gap good. The weird thing is once i drive car about 2 to 3 miles it goes away. If i try to accelerate when its cold miss is really bad.Once car is hot everything is fine. Im looking for confirmation on what i think is wrong. Will low compression on a cylinder cause this symptom? I always assumed that low compression would result in smoke but it doesn't smoke at all. I do have a cylinder with low compression. Im assuming that once engine is hot everything is tight and cylinder is firing. Any thoughts?
