Coronet_Arch
I just completed rebuilding the 383 for my 1967 Coronet. When I got the car it had a busted driver side engine mount. I was told the engine had been removed for the car to be painted. I bought two engine mounts from O'Rielly's, Power Torque. I set the engine in the car and could only get one of the new mounts to fit. After trying to get the engine started it turned out the engine needed rebuilt.
Now that the engine has been rebuilt I wanted to use both mounts. The engine was refusing to set down with the pins in the slots in the K member. The pins turned out to be longer than the pin on the original motor mount. I ground the pins down shorter and the motor now sets down in the slots. I also had to grind some excess metal from the driver's side mount to clear the steering box mount.
I managed to get the motor mounts to line up with the holes on the side the bolt is installed from, but the bolts will not line up with the holes on the other side. Today I noticed that the stud was longer than the one on the original and cut it down so two threads are showing. I am still having trouble getting the bolts to line up. Any suggestions?
