After I measured clearances I did take the friction and steel plates and dip them in transmission fluid before buttoning things up. I think the pistons seated OK - I plan to air test them. Not sure at what stage I can do that - I would like to before I put the pump in but I guess I could test install the pump to check end play and test the clutch piston then. Seems odd there isn't a seal on the inner piston hub - I guess the tolerances are close enough the pressure compensates for the small amount of leakage.
I'll try to find some new steel rings - these were obviously too small so not much point going back to Makco. Guess I'll venture over to the local transmission parts house out south of town tomorrow - go during early daylight and take some weaponry with me.
