Good thought on the joint line of the bushing. I'll have to watch that. I'm going to study the pressure diagrams on the servo seal. This is the outer piston in the servo to the front (front band - low band?) (Edit: this is wrong - it's the rear case servo for the low and reverse band.) so I don't see how there can be any pressure from the pan area acting on the exposed side and the lip should go to the inside - but I'll double check.
