Started back to work today on the 727 despite bad allergies - but quickly ran into another possible worn part I have overlooked. I focused on the front planetary so much that I overlooked wear on the back side of the rear planetary where it rides against the #8 steel thrust plate in the annulus gear. There's a pretty good groove worn there that pretty much matches up with the thrust plate.
It measures a little more than my .035 in feeler gage which probably accounts for most of my excessive end play in the planetary train. I did check the #8 shim thickness and it mics at .036 so it seems to be in shape. So basically the planetary is riding on the annulus case instead of the thrust washer.
Possibly having a bit too much Bubba in my blood I thought about putting one of my .010 metal shims on the rear of the planetary to run on the steel thrust plate.
I cut and bent some tabs to keep it locked to the planetary but I'm not sure this is a sound idea - I'll have steel running on steel?
Other thoughts - my #2 plan is I have a thinner brass shim (.055 inch) but that alone will reduce my overall end play to essentially zero.
My #3 plan is I also have a .040 composite thrust washer I could put between the planetary and the thrust plate #8. That should leave me with about .015 in end play - but will it hold up?
Or, #4 - I could go looking for a new rear planetary.
And finally, #5 is just run it as it is, although I'm wondering if this wasn't a contributor to some of my noise with the planetary case skimming the back of the annulus case.
Thoughts? I didn't really want to get this thing back together today anyway.
