I'm back - had some sinus head crap, had to wait on a snap ring and went to Colorado for my Dad's 92 birthday.
Did some reassembly this morning and looking for some reinforcement (hopefully positive) before I button things up.
I got a .051 in snap ring for the front of the rear shaft which is .06 inch less than the one I had on it. Without actually pulling it apart that should get me to .009 inch play on the planetary train, although I suspect it will loosen up slightly more once all the assembly lube is dissolved.
Test fit the clutch pack and pump after installing a .101 thrust washer behind the pump and things looked good so I went ahead and installed the rubber seal ring on the pump, reinstalled it and torqued to 175 in-lbs. Double checked the end play after moving the input back and forth until it was solid and got .041 which is just over the min. of .037.
But then I remembered in Carl's book that he said to force the rear shaft forward before checking play at the input shaft. So I tapped it forward and held it while re-checking the input again and
I got .020 end play - which is the total input/clutch pack/pump endplay.
So I have about .009 in the planetary and about .012 play in the rear bearing/snap ring to tailhousing assembly (from deduction). And I have .020 in the clutch pack/input shaft/pump assembly.
Although Carl says to check drivetrain end play in this manner (output held forward) I don't think I'm actually seeing any specifications stated for this approach. He has planetary end play at .010 to .044 inch and Drivetrain end play in Case at .037 to .084 inch. Does he mean on the Drivetrain end play to be .037 to .084 with the output held forward???? I slathered a good layer of assembly lube on all of the thrust washers so I wouldn't be surprised to gain 4 or 5 thousands additional play overall as soon as I run it but even so that will still leave me over .010 shy of that .037 inch spec. If that's to tight, then I will have to pull the pump again. I'm hoping some of you guys can weigh in on this.
By the way, this little rig I made up to pull the pump from the case works great. It's got to be better than fooling with slide hammers.
