Well they have to tighten up a little when knocked in,right?
I hope - to much trouble knocking them out and another one back in. I can see why they changed to a wider bushing later - surprised it took them 10 year to figure that out.
Curious about your sleeve repair...what type seals? Looks to be an easy enough fix! Beats the heck out of replacing the housing.
Don't really need anything special in the valve body. I always put mine together with good trans fluid, just making sure everything moves freely.
Hear ya on the o-rings. Yes, noted the wide seal grooves. Did they supply you with any 'back-up' rings? Their used on pretty much every a/c hydraulics I've dug into. Simply an o-ring, with two teflon back-up rings, one on each side of the o-ring. Just gives soft support for the rubber seal (from getting cut), and keeps it in place.
Removing the tail shaft bushing is easy collapse with a screw diver and hammer. I turned a piece of aluminum on the lathe to install. Make sure to make it a little small or it'll be stuck in the bushing once it's installed.
Doug
No, I would not try using the metal rings, not along with the o-ring. Besides, bore size is different. I'd use the repair kit as it comes, only with parts supplied...either going to work, or not.No - just the o-rings were included. I'll see if the metal rings fit inside the lands for grins.
Yes, the yoke should slip right in. Wonder what country the part was made in? But, past that, doesn't sound good. Maybe a call to the supplier, and ask what the hell? Hmm...sounds like something I'd do.The Inland output yoke is not fitting the output shaft properly.
Do the internal splines look okay? Needs to fit right.
