Front bearing retainer install...question.
64SF
9:04 PM
Ocala,Florida
I'm installing a new front bearing retainer gasket on an 883 4 speed.
The bearing retainer as what would would call a small "u shaped pocket" and the gasket provides a cut for it.
When the retainer is installed which position does the pocket go? Top? Bottom? Sides?
I didn't remove the retainer it came apart and there are no "witness" marks on the transmission housing.
Thanks.
Found the answer. Pocket aligns with the oil return hole on transmission case.
