Who makes one that is actually spring steel and works? I bought one and it spread out and didn't keep a snug grip on the fuel line.
Thanks in advance.
Thanks in advance.
Exactly what I was going to do as a plan B. Thanks.Unless you get NOS nobody I know of. I hose clamped some wire to the sender with a ring terminal to the frame up under by the tank. Works like a charm. The sender is still crapola. Maybe put a wanted ad in some one has to have a OEM one laying around.
After install, does it retain its spring pressure and actually ground/conduct?Plan B is an option but also Classic Industries has a stainless one too. Either or
Thanks! I may give that a try.This is the one I have and is fine
https://www.classicindustries.com/product/all-years/dodge/charger/parts/MF289.html
