ChryslerKid
- 2:03 PM
- Jun 6, 2020
- Sacramento California
Compression check and leak down was my next step. Ive got a couple projects 95% of the way done. Just trying to keep the main bearings intact while i start her up every once in a while until i can pull the motor. Had the power steering tensioner bolt snap in the block while i was replacing a belt. I had to drill and tap so i decided i might as well replace the water pump while the housing was off.. then i figured i might as well do the timing case gasket and crank seal while it was open.. you know how it goes.Install a double roller timing chain and gears during whatever rebuild you are planning. Might as well add a windage tray if it doesn't already have one.
Did you check cylinder pressures and leak down?
If im not mistaken bb mopars dont have water jackets in the intake and no oil to water contact in the timing case or water pump housing area so head gasket or freeze crack would be the two logical options eh? How would i tell the difference with a compression and leakdown test?It has water in there from someplace. Head gaskets rarely fail on stock BB mopars. Who knows what it’s been through and who worked on it. Freeze crack in that one? Gonna have to get into it and check it out. Can’t drive it like that.
Oil looked fine when i drained it. This is the first time ive seen milk. Just a film in the front of the oil pan. Its had antifreeze in it since ive owned it but she is 50 years old now who knows her history.Did it have antifreeze in it?
If you can't get to it right away, dump the coolant out, then drain the oil, put in new oil, start it for a few seconds and shut it off, then dump the oil again. Then let it sit until you can get to it. I'm betting something is cracked.
That was my first thought. I pulled the intake a year ago didnt see any cracks or water. Ive definately let it get up to temp but last week i pulled valve covers and one side had three significant splits where the bolts seat and a broken off bolt i had to take care of. Maybe wishful thinking ill probably pull the heads for good measure anyhow.You said you started it occasionally. Was it allowed to come up to full temp and for how long? Does it have a thermostat and what temp?
This could be condensation that hasn't burned off.
Looks worse than it is just a thin film in the front of the pan. Also its been raining hard for the last couple months.So the oil isn't all a slurry? It's just the white foam sitting on top of the oil and fairly thin?
Thank you guys i appreciate the input. Speaking of pcv the old owner had it unplugged. I had to throw on some cheap edlebrock valve covers while i get the old ones brazed. Its also got an aftermarket air cleaner with no snorkel or breather insert. Any downside to running a pcv valve on both sides with a T into the carb?I would also just pressure test the cooling system to be on the safe side...If you’re not adding water you could have condensation build up from short run periods or PCV issues... just my .02
dont use dual pcv valves.Thank you guys i appreciate the input. Speaking of pcv the old owner had it unplugged. I had to throw on some cheap edlebrock valve covers while i get the old ones brazed. Its also got an aftermarket air cleaner with no snorkel or breather insert. Any downside to running a pcv valve on both sides with a T into the carb?
