FOR SALE Hemi Prestolite Distributor Parts
Dragon Slayer
9:55 AM
Virginia
Feedback: 2 / 0 / 0
Original 1970/71 426 Hemi Prestolite Distributor shaft, cam and spring assembly. This is set up for auto and was replacement part for IBS4014E/17C distributor
This is new Old stock disassembled to remove preservative grease. Clean and ready for use. Cam has stock 12.5 degree distributor mechanical adv slot.
Could be used on other Prestolite dual point RB distributors. Comes with original box. $150. If you have worn or bent shaft or cam, this will restore your distributor to factory spec, or curve it to your needs.
New set of Super stock Hemi advance springs. Sealed bag. Used on the 64-65 super stock distributor. $10
New Old stock Dual point breaker plate, that has corrosion on the corner of plate. Points/condenser and bearing assembly undamaged and new. Sold
PM for contact info. Thank you
20200706_091933_resized.jpg 20200706_092032_resized.jpg View attachment 1009226 20200706_091913_resized.jpg
