Rackarboda
Will do, I just made myself a piston stop from an old spark plug, and will get back as soon as I've confirmed the actual TDC and checked the timing.
Yeah, I should of have done that a long time ago. I bought the cable last year, and couldn't find out how to put it. By the time I figured out someone assembled it wrong I had already switched carburetor to the carter, which lacks the correct throttle lever to attach a kickdown cable. Guess I will have to make someone handy manufacture one for me.Whoa- get the kick down hooked up&adjusted first. You'll lose the trans otherwise.
Yeah, that oughta work if I tighten the top attachment screw hard enough.This might work for you: https://www.summitracing.com/parts/edl-1481
When I pulled up at a nearby straight road and floored the pedal, you bet ya a wide grin drew upon my face combined with various obscenities of joy shouted into the atmosphere. When I released the throttle, a feeling of stupidity came flowing through my body and I cursed myself for a bit there. I knew the problem couldn't have been quite so hard, yet I already spent about $1.500 trying to figure out what was wrong. Most of the money was well spent, considering there were lots of stuff that had to be done sooner or later, but I could have spent them later on and prioritized for example correcting a paint job that looks like a smurf with psoriasis.Rack I hope you're smiling a little bit now?
