Hi guys I need Help
426hemii
New Member
7:34 AM
savannah GA
I have 68 charger with 727 and try to dicide which auto trans. shifter will fit orginal consule plate. B&M or Hurst has any shifter? Thank you...
just mesure the case hight compared to the inside hight of the console.prob need a ratchet type shifter,throw on the quick sticks and such is fairly long compared to a factory shifter.you will just need to make your own dust plate out of plastic to fit the shifter,but it should work.
