The rocker clips should be plastic with a plastic center push pin , the steel clips with studs will go on each end, the spring on each end clip keeps them in location, hook the top edge of the molding on each clip & snap it over the bottom edge of the plastic ones,
its good to have a buddy on the other end so you do not scratch the paint.
Side moldings should mount pretty much the same metal stud clips at each end, spring keeps them in location, plastic pops in.
if you are working with all new repop parts and the fit seems to tight use a little car wash soap on each before snapping it over.
