mag 500's off my Mopar, will they fit a 72 Mustang
moparfanUSA
6:02 PM
nj
Someone wants to buy my used magnum 500 7" x 14" rims that I have, is the bolt pattern the same so he can use them on his Mustang?
What mopar model? If the small pattern Dart/Valiant then no. If a B body, then yes. Both should be 5x4.5 bolt pattern.
At 14" x 7" they more than likely came off a Ford. Also X2 on grabberorange's comment
if its 5x4.5inch u can put mopar on ford products but not always vice verse (ford on mopar) as the center hole is to small...
Very true, but Magnums are not hub centric so cross swapping works fine.
If the has disc brakes it might not work i tried to put 14 inch magnums on my 71 torino gt they bolted on but when i tried to move the car it wouldnt move. they were hanging on the calipers so test fit them first,
