- 3:07 AM
- Mar 28, 2014
- South Louisiana
I am about to install a HitMaster launch control system in my 440 6bbl 70 Roadrunner. I currently have a 2,950 pound clamping pressure McLeod diaphragm style pressure plate, and the organic clutch disc. 18 spline, 10.5" diameter disc.
I spoke with McLeod and they basically said either you put wear on the disc, or wear on the flywheel and pressure plate.
They said the 100 series clutch disc I have is worth a try, and won't cost anything since I already have it. The 500 series clutch disc is the next step up to try, and it has organic material on the pp side, and ceramic on the flywheel side. My flywheel is "like new" and a billet steel unit I bought from Brewers.
So my thought is to try what I have and see if it can "take the heat" that the HitMaster will impart during the 1½ appx seconds delay to full clamping pressure.
My question is have any of you used the 500 series clutch disc (organic/ceramic) under track conditions where you are aggressively launching around 3,000 RPMs and how well did the disc, pp, and flywheel surfaces hold up, any scorching? How long did they last before you had to have any of those parts replaced or rebuilt?
Any alternatives to this setup that may work better?
Any other comments?
I am absolutely going to get the HitMaster launch control system, so that is not part of the discussion of options.
I would be interested in any personal experience with the "Soft-Lock" series by McLeod. That would actually replace the HitMaster as that disc material and pressure plate is designed to fully grab once heated, that heat being imparted in fractions of a second. The initial cold surface slips by design, and the heat that initial slip produces then causes the disc to grab.
Thanks!
Any other comments?
Thanks!
