moper
If you need to have a builder build it, and you are starting from a bare block, $10K should get you there but it will be close with a hydraulic roller. You need Chinese parts, and you will spend 1/3 or more on the machining and fixing the parts. A stroker is not a toss it together deal. Especially using the lower price point parts. You're basically building a 500hp 440 so you'll need enough head and cam to get that. Stealths and RPMs will both do that without porting. Both need some attention before they get bolted on.
