Need some Big Block Schoolin'
Darter6
11:08 AM
Nevada
I have a passion for doing odd ball stuff. I also work on a very small budget.Here is what I'm working on.1963 361 in need of pistons. One was damaged from a stuck valve. The bore is standard 4.125.They make tons of pistons of that bore size for Chevys. I know that the wrist pin size is smaller than Mopar. The question is can you bush the Mopar rod to use the Chevy piston ? Cost factor for the Chevy performance pistons is about $200 for 8. Looking up pistons for a 361 low po cast slugs is about $600 for 8.
I do like the challenge and also like to use what I have as far as Block, Crank and Rods.
Any advise for a novice at home engine builder ?
I guess anything is possible but you'll need to verify your compression height on those Cheby pistons first. Personally I would just get the pistons that are correct for your engine.
At a $400 cost difference, it’s worth the look and twisting the mind a little for the challenge. The cost difference could be rolled over to newer and lighter rods that already have the pin size needed with the Mopar journal. I think that rod is EZ to get, no?
If you contact the piston manufacturer, often they will adjust the off the shelf piston with 1 or 2 mods before they call it “custom” and charge more.
The thing that comes to mind is valve angles & the pistons valve pockets.
Pin height is also another adjustable spec.
I agree with "dryheat'. There is nothing wrong with adventure and experiments but every trip you make too the machine shop it costs more money. :drama:
The answer is yes, you could make a bushing for the rods. However, you need to turn the bushing, press it in and then machine the hole to the proper size which is a close tolerance. But you have approx .350 difference in compression height. A 361 B block is very different from a SBC.
There are piston kits at Summit for the 361 in the $400+ price range. You can also purchase one piston.
Once you confirm that the compression height, valve reliefs, etc will all work I'd order pistons set up for a floating pin and bush the rods. This is very common in performance builds so it should be doable.
More trouble and cost than it's worth. Small bore 361, poor head. Better off to find a cast off 383 that runs ok .
Doug
Doug
For general performance, it'll be OK.
I'll tell ya small block guys (340/360 engines) would love that head and valve size stock on there mills.
Thanks for all the info. I know it's odd,I just hate to scrap things that have possible use. This was just a thought about what to do with it.We pulled it out of a car 40 years ago. Maybe I'll just keep the crank.Not that I need another project.
As far as heads go I do have a set of worked 440 Source heads.
You guys know the story "I have this intake,maybe I'll build a engine around it.God knows I can't get rid of it".:lol:
