KL_Mopar_GTX
Welcome from South East Michigan, great place for info and great like minded people
What are the part numbers and brand? Save me some web searching
You know about the 516 heads, right?
Yes, closed chamber - and have the smaller 1.6" exhaust valve, along with smaller exhaust ports in need of someI should rephrase that they are most likely the stock 516 heads, I actually haven't checked into them that much. Should be closed chamber, probably soft valve seats unless the previous owner upgraded them when it was rebuilt a while back. With the head gaskets on it, flat top pistons, and only 130psi cranking I can't figure those heads should be much of an issue for the time being? I'm using some really cold plugs and pulling a ton of timing as well.
Mike
